Insight -- LinkFixupMgr.exe Exception Error
I'm receiving an application popup for LinkFixupMgr.exe quite often. It comes up if I try to run "Update Secure Links" from the Insight server, and it is also waiting to greet me on the same server, seemingly each morning when I get to work. Here is the error:
LinkFixupMgr.exe Application Error : The exception unknown software exception (0xc0000005) occurred in the application at location 0x0096ab9b.
My cache and log folders are in the same location on the Insight server. The cache folder is empty, the log folder is not. I've attached the log file "InsightLinkFixupUserLog#####" As for cache location, each of my users utilizes their own local cache for speed considerations, so I'm not sure that my cache is pointed in the right place.
Any ideas as to why this would be happening would be much appreciated. Thanks.
RE: Insight -- LinkFixupMgr.exe Exception Error
Ken G.
http://grundey.blogspot.com
To eliminate the performance hit, the LinkFixUpMgr service would use the event sink logs to find out what had changed (moves/renames) and would fix the paths in batch, usually during low usage times (scheduled by the admin).
Now that paths are not used at all for link resolution, it is no longer necessary for it to run.
Ken G.
