ms plates used for ship construction
i ma repeating this from yet another forum because i got no response>
Q: are there any chemical tests carried out on plates used for constructionof ships?
what are the normal DT and NDT on materials used for ship construction and allowable standards for the same ?
tahnx.
tahnx.
RE: ms plates used for ship construction
If so, you should refer to appropriate ASME code for design and fabrication of Boiler nad Pressure Vessels. Section 8 (Division 1) will deal about the engineering and Section 2 (Part A) will give the material specification. But you should go through the whole catalogue of ASME to find out whether they have any recommendation for ship building.
G'Luck.
flame
