AB 160 VFD argh!
AB 160 VFD argh!
I have a 160-AA08NSF1 hooked to a motor and powered up.
Link Location:
http:/ /literatur e.rockwell automation .com/idc/g roups/lite rature/doc uments/um/ 0160-um009 _-en-e.pdf
I've set P46 to "2" so I can theoretically control the motor entirely from the keyboard.
I've set P59 to 1 to use the internal freq source.
I've set P58 to 3.0Hz so if this thing starts(-ever-) I don't spin the pump fast in the wrong direction.
I can not get it to output any drive.
I'm running under the belief that I need no other FWD, START, etc., etc., wiring to just turn get the motor going and vary the speed. Am I mistaken? (-probably-)
Link Location:
http:/
Keith Cress
RE: AB 160 VFD argh!
I have done both even though I read that as (either power cycle OR P56=>2).
No Joy.
Keith Cress
Keith Cress
