LPG tank outlet pressure
Does anyone know what a typical vapor pressure at the outlet of a 500-1000 gallon propane storage tank is....after it has been regulated down? I assume that the propane tank has a pressure regulator on it. I have a 1000-gallon propane tank on site that will feed 3 buildings. Each building will have a separate pressure regulator. I'm trying to size the pipe sizes from the propane tank to the buildings, but not sure what a typical outlet pressure is on the tank.
Each tank has its own pressure regulator that is installed by the manufacturer correct? I wonder if this outlet pressure from the tank is set by the standards/codes or can be specified by the engineer when the tank is purchased?
Thanks.
Thanks.
RE: LPG tank outlet pressure
Richard A. Cornelius, P.E.
WWW.amlinereast.com
htt
