Refrig Test Pressure
I have a spec that reads, "Second stage tests shall raise the system to the minimum refrigerant leakage test pressure specified in ASHRAE 15 & 34 with a maximum test pressure 25 percent greater."
Any idea what the specified pressure in ASHRAE 15 & 34 is?
RE: Refrig Test Pressure
http://www.ashrae.org/docLib/200369145743_347.pdf
