Clutch-type LSD setup
Hi, I have a few questions on the effects of settings available in clutch-lsd setup:
-What is the relationship between engine torque and static % lockup? As far as I understand any clutch diff will lock 100% (of the static setting?) when fully loaded. Is the static % lockup just the max distribution between the wheels?
-How much do ramp angle and preload affect initial lockup compared to each other?
-How much do ramp angle and % lockup affect abruptness of lock/unlock action in low grip situations like snow and gravel?
-What's the difference between tuning with diff components versus friction modifier? Does friction modifier affect ultimate % lockup or other areas of operation too?
Thanks.
Thanks.
RE: Clutch-type LSD setup
And it's never unlocked
Are You sure You don't ask Lock-right ??
Your question can not be accurately answered without know exactly which design you are referring to.
As noted, clutch type LSD's don't actually lock. Some slippage in normal use depending on the clutch pack pre load setting. A locking diff is by some mechanical means whereby the axles are physically "locked" together. NO slippage.
I use both types. I set the clutch type (TranX) for minimal slippage...just enough to make the car (Mini Cooper) manageable in the pits/paddock. The locker (Detroit Locker) is in a rear drive (Lotus Cortina) and functions as designed. Some do not like the Detroit cam and spring setup as it makes noise in a slow turn...I've grown used to it.
Rod
