Flow out time vessel, viscosity fluid
I am a mechanical engineer at the moment I am trying to determine the flow out time of fluid in a tank.
The fluid has a viscosity of 200cP, how do I determine the flow out time of an atmospheric tank.
The tank has a capacity 18m³
How much influence has the viscosity of an fluid on the flow out time of a tank.
Which formula can I use.
RE: Flow out time vessel, viscosity fluid
Hi Eino,
Are you a student?
If so you should post in the student section of www.Cheresources.com
If not, try the pipelines, Piping and Fluid mechanics engineering forum.
The best thing is to buy a copy of the Crane fluid flow 410 manual.
Yes, viscosity has a significant effect, by the way.
JMW
www.ViscoAnalyser.com
If it flows through a pipe, you should calculate Reynolds, and most likely you can use for laminar flow the poisseuile equation:
dp = 32 eta v l / d^2
p = pressure drop (fluid column/2)
eta = viscosity
v = fluid velocity
l = length of pipe
d = diameter of pipe
Velocity will decrease as the tank gets more empty.
DYV
This should be in any fluids book.
Tobalcane
"If you avoid failure, you also avoid success."
i'm sure it is ! ... as i remember it, the hardest thing to quantify is Cd, though i suspect that there are standard values that can be used.
