Quadro 4600 moded from 8800GTS w/ no realview ?
Hey guys,
I am trying to soft-mod my 8800GTS into Quadro 4600 with rivatuner so I can have Realview in Solidworks. I tried before, it worked.
Later one of my computer memory died and i switched back to 8800 due to stability issue. Now i have new memory but cannot get the realview to work any more.
I followed the tutorial here:
htt p://www.ra ge3d.com/b oard/showt hread.php? t=33898714
Any idea how to solve the problem?
Thanks in advance.
Youyou
htt
Thanks in advance.
Youyou
RE: Quadro 4600 moded from 8800GTS w/ no realview ?
Good Luck
Gerald
Did you by any chance use a different Quadro driver version when you modded it the second time? And maybe a silly question, did you verify that your OS sees a Quadro right now?
I went with a new Fx580 card in the end. Don't feel like spending more time to make the 8800 work. plus i will be getting full features from the new card.
Thanks again.
I use to use quadro 4600 moded from a 8800gts. after first done this, driver was picked up by windows 7 and realview works great. then there is some problem i switched back to 8800gts. when i moded it again into 4600, realview stopped working. i tried different drivers it didn;t work.
so i thought it might be my video card's problem. then i purchased a fx580 from amazon and now, still no realview.i tried various drivers and uninstalled solidworks 3 times, plus creating new user profile in windows, etc etc. no luck.
any one know what got stucked?
thanks,
Yes and it is shaded out which I cannot uncheck.
thank you very much CorBlimeyLimey
