Tolerance in view style
What is the meaning of the tolerance in view style? Do I need to increase/decrease this value? Or let it system decide?
NX4.0.4.2 mp10
win xp 32bit
NX4.0.4.2 mp10
win xp 32bit
RE: Tolerance in view style
That being said, why are you asking whether you need to "increase/decrease" this value? What is it that you're seeing which makes you think that it needs to be changed?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
So it's just intresting what is the meaning of it. Is it milimeters? If I do not need this number at all, so why I'm seeing it and it is possible to enter any value?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Does it meen, that my drafting view can be presented (ploted?) with inaccuracy of about 4mm?
John R. Baker, P.E.
Industry Sector
Cypress, CA
@John,
I did not understand the meaning of the description given. Can you elaborate it.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Proud Member of the Reality-Based Community..
So when we say 'Chordal Height' we are talking about the difference between the theoretical curve and the line segments which are being used to render it, as shown in the exaggerated image attached to this post.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Since the move to NX6, I haven't had much need to change the value. From personal experience, I have not noticed much difference in the time it takes to update the drawing whether a small or large value is used, but then again I don't believe I've ever taken it all the way down to 0.
What are the units of this variable, and can someone suggest an optimun value for a feller that typically makes "B", "C", "D", and "E" size drawings?
If you're working in Metric I would set this to around 0.100 and if Imperial units, 0.005.
John R. Baker, P.E.
Industry Sector
Cypress, CA
The Customer Defaults > Drafting > View > Units System is either "Metric" or "English", and does not convert when the user changes units.....?
I will try "English" at .005, and report back....thanks.
capn
Note that if you open the Help files and search on Chord Height Tolerance and select the first result (General options) you will go to a page which explains all of this and provides examples using images similar to what I posted earlier.
John R. Baker, P.E.
Industry Sector
Cypress, CA
So, does this "optimum" refer to optimum drawing accuracy, or optimum time to generate the drawing? Two different requirements here ---- do I have a choice?
"The smaller the specified value the more accurate the representation. However, smaller tolerance values cause longer update times."
That should have been a clue that the term 'optimum' was speaking more along the lines of some 'happy medium'.
As for you "having a choice", if we didn't want you to have a choice, we would NOT have allowed you to override the default. By entering some non-zero value, you are indicating what it is that your preferences are. Now as to exactly what that value should be, since it has already been pointed out that there are many variables, you will need to experiment and find out for yourself and your situation as to what is an 'optimal' value to use. Good luck.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Do you have 'extract associative edges' toggled on in your views? If so, this may be adding to the time it takes to update.
That being said, before I would start second guessing the system, I have to ask, why are you looking to change what the system thinks is 'optimal'? What behavior or symptoms have you experienced which has led you to conclude that you needed to change the value of the Chordal Height Tolerance?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Customer Defaults -> Drafting -> View -> Threads
...and toggle OFF the 'True Hidden Line' option.
John R. Baker, P.E.
Industry Sector
Cypress, CA
The verrrry slow updating of my top-level assembly drawings is the symptom I am trying to alleviate, by investigating the chordal tolerance variable.......which I am now concluding that for some nefarious reason is being brushed under the rug, so to speak, insofar as the explanations I have been given as to what the optimal value for this tolerance is, and how it is magically derived and not revealed to me anywhere.
As long as I put my faith in the system, enter zero, and take the result I am given, everything will be just fine, eh? I don't believe it. Show me, I used to be from Missouri.
If the number is not zero, can the system report to me what value is being used, so that I have a starting point to use for weighing the trade-off between accuracy and time..?
NX 7.5.1.5
BTW, where are you located? Over the next 2 months I'm going to be traveling across about half the country (Eastern half) and who knows, I might be passing close by...
John R. Baker, P.E.
Industry Sector
Cypress, CA
