switch or case statement for excel spreadsheet
I don't know about you, but I have always been annoyed that excel doesn't provide a switch or case statement (at least not that I know of). So I wrote one in vba that can be called from excel.   Tends to help avoid complicated nested if logic.
CODE
Function sw(ParamArray invar())
    ' implement logic similar to switch
    ' example call
    '  =switch(boolean1, value1, boolean2, value2, boolean3, value3....)
    '    returns the value corresponding to the first true boolean
    ' at least one of the boolean expressions must be true
    ' requires an even number of arguments
    ' the syntax is pretty much identical to vba switch, except that there is no explicit allowance for else value
    ' if you want an else clause, enter true for the next to last argument, followed by the associated value
    ' Note that indexing of invar starts at 0, regardless of Option Base statement
    ' Check to confirm even number of arguments (as required)
    If UBound(invar) Mod 2 <> 1 Then MsgBox "Error: Need even number of arguments for sw"
    Dim ctr As Long        ' loop counter
    Dim tempswitch As Variant        ' variable which will hold the output value
    ctr = 0        ' initialize counter
    Do While True        ' loop until broken by exit command
        ' Check for boolean input
        If VarType(invar(ctr)) <> vbBoolean Then MsgBox "Error 1st 3rd 5th etc arguments of sw must be boolean"
        If invar(ctr) Then        ' in this case have found a true value, assign function and exit
            tempswitch = invar(ctr + 1)
            sw = tempswitch
            Exit Do
        Else        ' Else have not found true yet, update counter and continue loop
            ctr = ctr + 2
        End If
        ' Check for reaching end of invar without having found true
        If ctr + 1 > UBound(invar) Then MsgBox "Error: sw needs at least one true boolean argument"
    Loop
End Function
(2B)+(2B)'  ?
RE: switch or case statement for excel spreadsheet
Thanks Pete.
I didn't even know about the VBA Switch function, so I haven't been missing it, but I'm sure I'll find a use for it.
Do you know if there is a way to copy and paste from here into the VBE without losing all the line breaks?
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
IDS,
a simple task to copy the text and paste into Module.
although it has been awhile (years) since writing some VBA, i seem to recall a select case or case is statement.  i could be wrong as i've CRS (can't remember stuff) lately.
good luck!
-pmover
When I copy the text and paste it into a module I lose all the line breaks; i.e. the text all goes onto one line.
Yes, there is a Select Case statement in VBA.
Doug Jenkins
Doug - the cut/paste works ok for me and even preserves the indentation.  But anyway I have put it into a spreadsheet and uploaded it here if that helps.
pmover - the purpose of the function is not to add a new capability to vba... it is to add a new capability to spreadsheets.
(2B)+(2B)'  ?
Thanks Pete.
Losing the line breaks is probably an exciting new feature in Excel 2010, or Windows 7, or something.
Serves me right for being a compulsive "up"grader.
Doug Jenkins
