Padeye dimensions
Padeye dimensions
Can any one help me regarding padeye dimensions to DNV standard.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Padeye dimensions
BA
I think the question is directed at what diameter the padeye hole should be for a given shackle pin...but maybe psaum can elaborate.
1-1/2", 17 tonne Working load limit shackle as 59mm thick
1-1/8", 9-1/2 tonne Working load limit shackle as 45mm thick
1", 8-1/2" tonne Working load limit shackle as 41mm thick
I am just curious to find out if the above is correct.
Hope this makes sense.....
DNV (Det Norske Veritas) is a standard that we are working to....they have a standard DNV 2.7-1 and 2.7-3 both have some info on padeyes.
