Translating a NX6 Assembly in a single STEP214 File?
Have an issue that is hopefully a quick fix, how do I translate an NX6 Assembly into a single STEP214 file?
My attempts so far have yielded a series of STEP214 files, emulating the assembly structure of the NX6 files.
RE: Translating a NX6 Assembly in a single STEP214 File?
you missed a setting in the options:
turn off external references in the advanced tab
Tried that before uwam2ie - and I get a STEP with no geometry from the subassemblies and/or compoenents.
UG to STEP
! INFO-     NX STEP AP214 - V6.0
! INFO-
! INFO-     Start of Translation: 13-SEP-2010  7:49:46 AM
! INFO-
! STATUS-   Converting Part: u:\Import_Export_Demo_10SEP10\Native_UG\First_Version\Part_01A.prt
! SUMMARY-
! SUMMARY-  Summary of Unigraphics Part Entities
! SUMMARY-  For Part: u:\Import_Export_Demo_10SEP10\Native_UG\First_Version\Part_01A.prt
! SUMMARY-  Entities Processed             Count
! SUMMARY-  ------------------             -----
! SUMMARY-  Part Attribute ..............:     1
! SUMMARY-  Font ........................:     1
! SUMMARY-  Color Table .................:     1
! SUMMARY-  Coordinate System ...........:     1
! SUMMARY-  Parameter ...................:     1
! SUMMARY-  Matrix ......................:     1
! SUMMARY-                                 -----
! SUMMARY-  Total                              6
! STATUS-
! STATUS-   Converting to Output Form (Phase 2 of 3): 13-SEP-2010 7:49:46 AM
! STATUS-
! STATUS-
! STATUS-   Generating UG geometry and placing them in parts
! STATUS-
! SUMMARY-
! SUMMARY-    STEP Header Information
! SUMMARY-
! SUMMARY-  Description      Second Version
! SUMMARY-  Imp_Level        1
! SUMMARY-  File_Name        Part_01A.stp
! SUMMARY-  Date             2010-09-13T07:49:46-05:00
! SUMMARY-  Author           John Doe
! SUMMARY-  Organization     XYZ
! SUMMARY-  Pre_Version      ST-DEVELOPER v11
! SUMMARY-  Orig_System      SIEMENS UGS NX 6.0
! SUMMARY-  Authorization    None
! SUMMARY-
! SUMMARY-    Summary of STEP Entities
! SUMMARY-
! SUMMARY-  Entity Type                                                   Count
! SUMMARY-  -----------                                                   ------
! SUMMARY-  application_context ........................................:      1
! SUMMARY-  application_protocol_definition ............................:      1
! SUMMARY-  axis2_placement_3d .........................................:      1
! SUMMARY-  cartesian_point ............................................:      1
! SUMMARY-  conversion_based_unit_and_plane_angle_unit .................:      1
! SUMMARY-  dimensional_exponents ......................................:      1
! SUMMARY-  direction ..................................................:      2
! SUMMARY-  geometric_representation_context_and_global_uncertainty_a ..:      1
! SUMMARY-  length_unit_and_si_unit ....................................:      1
! SUMMARY-  plane_angle_measure_with_unit ..............................:      1
! SUMMARY-  plane_angle_unit_and_si_unit ...............................:      1
! SUMMARY-  product ....................................................:      1
! SUMMARY-  product_context ............................................:      1
! SUMMARY-  product_definition .........................................:      1
! SUMMARY-  product_definition_context .................................:      1
! SUMMARY-  product_definition_formation_with_specified_source .........:      1
! SUMMARY-  product_definition_shape ...................................:      1
! SUMMARY-  product_related_product_category ...........................:      1
! SUMMARY-  shape_definition_representation ............................:      1
! SUMMARY-  shape_representation .......................................:      1
! SUMMARY-  si_unit_and_solid_angle_unit ...............................:      1
! SUMMARY-  uncertainty_measure_with_unit ..............................:      1
! SUMMARY-                                                               -------
! SUMMARY-  Total                                                             23
! INFO-
! INFO-     User interface/default file
! INFO-     Bspline aprx. value in effect for this translation : 2.540000e-002 mm
! INFO-
! INFO-     Total number of solids input for this translation  :       0
! INFO-
! INFO-     Number of solids processed without problems        :       0
! INFO-
! INFO-     Number of solids with problems output as sheets    :       0
! INFO-
! INFO-     Number of solids not processed                     :       0
! INFO-
! INFO-     End of Translation: 13-SEP-2010  7:49:47 AM
! INFO-
how do you start from file export or ftom File save as *.stp?
File -> Export -> STEP214
try from save as,
 what exact nx 6 version are you running?
NX 6.0.2.8 191(build 310)
Hm... appears that the "Save As" method worked without issue, NX6 assembly into mono STEP214 file.  However, working on a write up for users, and the "save as" option could be a quick way for trouble (i.e. user saves the file as something else, step203, etc.), was trying to get the File -> Export -> STEP214 to behave correctly.
