Ball Burnishing of a 6 Lobe profile using CNC
Here is the problem: we manufacture fasteners and among those there are some Self Clinching Fasteners. They have a special feature under the head that helps "clinch" them to the sheet metal. The die that makes that feature breaks very fast. Currently we use EDM to burn the profile of the feature. The surface roughness is not that good and is very difficult to polish that kind of profile (6 lobes). I was reading about the burnishing and I wonder if we can use it on our dies using a CNC machine. The profile is like a flower with 6 lobes. The radius on the bottom of the profile cavity is the starting point of the fracture (most of the times). I was thinking of improving the surface finish and work harden that area in order to improve the fatigue life of the die and for that I was looking at the Ball Burnishing process. Any thoughts on this subject? Would it be feasible?
Formcast
Formcast
RE: Ball Burnishing of a 6 Lobe profile using CNC
For assistance with roller burnishing, try Ecoroll:
http://www.ecoroll.com/
Mike Halloran
Pembroke Pines, FL, USA
If not look into micro polishing, this can be done mechanically, electrically or chemically, speak to someone who specialises in this field, or wait for a post on here from someone who does.
Look at the tool steel you use and hardness, many people stick with the more generic steels they know but there are some amazing "new" ones out there, I have always found Bohler Uddeholm a very good company with excellent technical support but you may have a preferred supplier.
Finally look at coating the part, this can offer huge improvements and don't just go for the more generic coatings. I have always found Oerlikon Balzers to be an excellent company that offer very good technical support and a first class service.
The material is M2, Rc 58-60. I'll consider all suggestions.
We did order it outside and we asked for a better finish on the feature, but we didn't get quite the finish we were looking for. Burn it in-house, polish it a bit on the surface and breaking the top edge gave us the same tool life, so it's not practical to pay extra money for something you can do. Still, the tool life is poor and this is what I was trying to change. Thanks again for the help.
