ASTM spec editions
ASTM spec editions
I am using 1989 ASME B31.1 and Appendix F lists various ASTM specs and the edition years.
Am I locked into using the editions listed in the 1989 version of B31.1 or is it acceptable to use the current ASTM spec editions.
Is there a reference that would allow me to use the newer versions.
thanks
Mark
thanks
Mark
RE: ASTM spec editions
If you are required to use the 1989 edition of B31.1, the associated references in Appendix F would also apply. These are references approved for use by B31.1. Later editions of B31.1 may or may not endorse these same references or may take exception to later aditions of these references.
