Parasolid Assemblies
Is there any way that we can control the naming output of Parasolid Assemblies in NX. I was amazed to find having been given a file from another system with names I wanted to change that I simply could not do so. No matter how I tried too rename the files when output to Parasolid and imported back into NX they always retain the original names.
Add to that that when I output data from other NX files to Parasolid the assembly names are not the same as the original assembly whereas data from some other systems appears to be able to reproduce the correct structure.
Is there some setting I need to change?
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
RE: Parasolid Assemblies
Best Regards
Hudson
www.jamb.com.au
Neither have I ever been bothered about identifying what the components are. If I wanted to do that I would export the individual parts as parasolids and build a new 'lite' assembly.
Possibly going off on a tangent but ... I've found with other software (notably MS Excel) that if you can't do something, then its often that its illogical to do so.
Now don't take this the wrong way, because I know your one of the respected gurus on this site and I've personally valued your input, but I always challenge my colleagues to take a step back and assess whether their workflow is sound.
That said ... NX is always evolving and by that very nature you may be on to something worthy of a user enhancement request?
Either way I hope you find what your looking for ...
Jon S
Medical Design Engineer - Glos. UK
NX 6.0.4.3 / TCE V10.0.3.8.6
Jon S
Best Regards
Hudson
www.jamb.com.au
