Compressive steel
Compressive steel
i need help determining the area of compressive steel for a T Beam...i have already found the area of tensile steel. I need to check the beam for strength and ductility and require the area of compressive steel but im new to design and cant seem to find anything in the concrete design codes AS3600. any help would be appreciated...
RE: Compressive steel
Unless you require some compressive steel for service requirements such as deflections.
An expert is a man who has made all the mistakes which can be made in a very narrow field
Clause 8.1.5 and a good textbook as suggested above.
AS3600 will not tell you how to calculate a double reinforced member, that is textbook stuff, not code stuff.
