Attribute Inheritance for DB_PART_REV not applied
Have come across an issue where our drafting parts list does not show the correct revision for some parts when compared to the ANT. See attached part 16P2053 is shown as rev D in the ANT. If you right click on the part in the ANT and select properties->attributes the attribute DB_PART_REV shows rev C and there is no inherited icon next to the attribute name like the other DB attributes. If you do the same with part PL16M6065 the correct revision is shown and the DB_PART_REV attribute has the inherited icon next to it.
How do I get this attribute for this component to be inherited again and show the correct revision. I can not edit or delete this attribute as it is a database attribute controlled by TC.
If I create a new drawing specification for this assembly the component attributes are all inherited correctly, but then I would have to recreate the drawing. I am hoping there is a way to fresh this attribute somehow. I have tried Format->Database attributes->Reload, right clicking the ANT and selecting Refresh Teamcenter Information, loading all components fully.
Clayton
NX7.0.1.7 MP1 Mach 1 Bundle
TC 8.1
Clayton
TC 8.1
NX 7.0.1.7, TC 8.1
RE: Attribute Inheritance for DB_PART_REV not applied
NX 7.0.1.7, TC 8.1
