Australian earthing designs IEEE80 or AS2067
Hi guys,
I need to design a substation's (33/11kV 3x15MVA transformers) earth grid. My problem is that I can't clearly find what compliance I need to achieve to conform to the Australian Standards. If I refer to substation earthing guide ENA EG1-2006 there is a clear statement which reads "It is recommended until further international standardisation occurs that the American IEEE Std 80 approach be used for substation under ESAA Guidelines." In the other hand if I refer to AS2067 there are no clear guidelines as to what is the basis of earthing design.
Is there an Australian standard that clearly defines the conformity requirements that need to be met and if I follow IEEE80 as the design basis for my earthing design will I conform to local Oz requirements?
-polo78
-polo78
RE: Australian earthing designs IEEE80 or AS2067
Marmite
-polo78
Best regards,
norgear
Rafiq Bulsara
http://www.srengineersct.com
