Dose anyone have the origional ugcolor_nx7.cdf?
Looking to get the origional ugcolor_nx7.cdf file for NX7 that has not been altered?
NX6.0.4.3 mp02, Windows XP 32-bit
Running cad straight out of the box is OK but, a system tuned with application software is the best way to increase productivity.
RE: Dose anyone have the origional ugcolor_nx7.cdf?
Is is the same as the NX6 cdf file?
As you just found out it is probably a good idea to keep a copy of the default color palette someplace - I learned that a long time ago.
We are not on NX7 yet but will be moving in the near future.
NX6.0.4.3 mp02, Windows XP 32-bit,Team Center 9.1
This is a part file that I created to load the vairous color definitions to see how the color pallet changes.
I used this to write a program to change the current part from its color definition to any other selected color definition from UG16 through NX7.
@cadmantools
do you color your faces for surface finishing in cam?
Yes
into the V5 world?
see thread561-244752: UG color definition file
