Revolves producing strange angles.
Look at attachment
When I make a revolve (sometimes), the geometry does not match what it was supposed to and has many angles that were not supposed to be there. When I put into a drawing it seems fine, all I am worried about is when I go to do this in CAM, that it will follow the incorrect geometry.
If it wont do anything and its just a visual problem with Solid Edge than I can live with that, but I would just like to be safe.
Jordan
Jordan
RE: Revolves producing strange angles.
By default this is set at '2' to get better performance if memory serves, but this means that circles may appear as octagons or the like.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Thank You
Jordan
