Joint results tables in reports
So I can't seem to get the joint results to show up in my reports. It doesn't work for either the default file of the custom one I have. Title shows up in the report, but not the tables. The table are in the model and it has saved results. the xml code for the report is:
<item>
<table>
<blank_line_after>1</blank_line_after>
<table_id>
<key>Joint Displacements</key>
</table_id>
</table>
</item>
Is there something wrong here? Anyone else have this problem, know how to fix it?
<item>
<table>
<table_id>
</table_id>
</table>
</item>
