SAFE Design Strips are getting deleted
I have encountered some sort of a bug in SAFE where it is deleting my design strips when I run the model. I have my design strips spaced at 1 meter in both directions on the slab. I am using SAFE Version 12.3.0.
It is only 3 design strips that keep getting deleted. It is the same 3 every time. I unlock the model, draw them in again, run it and then the same 3 design strips are disappearing. The design strips do not seem to be overlapping with any other area object. I tested extending an adjacent design strip to 2 meters and it ran fine that way. It did not disappear. In my calcs though I need to be consistent with my design strip widths, 1 meter.
Anyone have any ideas as to why this might be happening or any suggestions on how to trick the program into not deleting any design strips?
Thanks for your input!
Lisette
![[afro] afro](https://www.tipmaster.com/images/afro.gif)
Lisette
