basic problem involving Internal energy and entropy of a vessel
The problem is:
A 2ft^3 vessel is filled w/ 1 lbm of water at 100psia. What is the total internal energy and entropy of the vessel?
It's been a while since working a problem like this, any ideas?
Everything is greatly appreciated, many thanks in advance
RE: basic problem involving Internal energy and entropy of a vessel
You have P= 100psia, and v= 2./1. = 2 ft3/lbm.
so now use a steam table and obtain the rest.
Since 0.5 lb/cf is not the density of the water at 100 psia, can you tell us the temperature?
from the following online steam tables
<http://www.steamtablesonline.com/steam97web.aspx>
p=100., T= 327.8, v= 2.0, h= 697.7, s=0.981216
units are english units, not metric.
My steam tables didn't show a value for the given data. Therefore I had to assume it is a mixture of liquid and vapor.
It appears to be wet steam with a 44.9% quality as shown by the "calculator" suggested by davefitz.
I was referring to dry steam. I agree with you that wet steam (44.9% dryness) has the values of enthalpy reported by davefitz
It cannot apply when the two given properties are saturation pressure and temperature. In this case one needs an extensive property.
Or, of course, the steam quality.
Or specific volume, which is another intensive property.
