Phoenix contact terminals blocks
Hello all,
For a few years my company has been using the screwtype terminals on all the equipment we use. Our equipment gets shipped all over the world to different rigs and suffers lots of vibration enroute. Well we seem to always be having problems traced to wires that came loose.
I am trying Phoenix contact's Clipline terminals, and I am loving them. They have a nice layout, easy to jumper, and have the springer type terminal which really holds the wires in. But I have come to a lot of opposition with some of our people, which I think is mainly motivated by polictics.
I have only seen a few threads about screw vs spring and they seem a few years old.
So what have some of you experienced and does the Clipline product deliver? Phoenix seems to me a very good company and we use a lot of their products already.
RE: Phoenix contact terminals blocks
With regards to vibration issues, Wago claims specialty in making cage/spring clamp blocks for high vibration environments. According to the salesman I last spoke with, the connectors were developed for a large diesel engine application where the screw type was failing. From what I recall, their connector makes a non wire breaking type crimp that grips the wire very forcefully and they are near impossible to pull out without releasing the clamp. They are not, however, the least expensive.
Almost all of our equipment is used in high vibration areas.
Another issue I like with their line is the way I can bridge and configure layouts. I refuse to put more than one wire in a terminal, as I have seen it done so many times, and it causes more problems. Also I like how some of the blocks will use the Din-rail to tie to earth ground, so I don't have to have so many ground wires jumpered.
I am not the one that works on the equipment in the field. So my goal is to keep it simple and laidout in a way that a new technician with no experience or pretending to know something can see a more intuitive layout. I not worried about spending more on parts if the downtime of our equipment is reduced. We lose more money when we are not operating than on replacement parts.
My first exposure was to the Wago system. I loved it for my shop assembly process because my wiremen could zip through a panel assembly in about 1/3 the time. Once in the field though, I absolutely hated it! I never had the right tool to remove a wire that needed to be changed or for troubleshooting a circuit. When desperate, I used a screwdriver to release the springs and ended up damaging the block, the wire or in most cases both. That push-in spring clip would create a barb on the conductors and that barb would often grip the edges of the clip even when the clip was open. In a few instances I ended up shortening the wire too much because I had to remove the damaged ends, which made matters even worse. I was doing a large project for Boeing, they witnessed the entire fiasco and subsequently banned Wago terminal blocks for years.
Since then, I have learned that there are two types of spring loaded terminal systems: the "push-in" style that Wago sold me (they actually offer both, the salesman didn't mention that) and the type where you use a tool (i.e. screw driver) to open the block before inserting the wire, then when you remove it the spring clip holds it. This is the type Phoenix is promoting (although like Wago, they too have both). Incidentally, Phoenix and Siemens developed their systems jointly, you can buy them from either one. It was when using the Siemens spring clamp terminals that I changed my mind on them. The type where you open the terminal first then it springs to clamp when you remove the tool is far far superior to what I experienced the first time. They do not damage the wire, they do not vibrate loose. The fact that a standard narrow screwdriver is the basic tool also makes it very convenient for field work.
I think now that much of the resistance to the technology comes from people, like me, who experienced those earlier versions that were way more trouble than they were worth. I found that a simple demonstration was usually sufficient to change the minds of most reasonable engineers.
But we all know that some engineers are not always reasonable. Emotions play a big part and one bad experience can create a lifetime of objection. Good luck with that.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Keith Cress
I must admit that for high vibration areas I can see the advanatges, although I don't think they are as good as Weidmuller's RSF series of spring-loaded terminals designed for use with a lipped blade. We use them a lot on CT circuits where loose terminals can quickly become a dangerous situation. RSF's are much more expensive than the cage clamp type though.
As for wire that is constantly removed, wire is cheap, it can always be replaced. Now the parts that get shorted because of control wiring messed up, that is costly.
sorry for the rambling. Waking up and trying to get caffiene in my body for another day of fixing stuff for people.
Ferrules are your friend. I really like the parts from American Electrical Inc for medium/small stuff so I'll give them a plug here.
John D
I still have the scars to prove it...
"As for wire that is constantly removed, wire is cheap...". Within a panel I accept that it's fairly cheap, although the downtime incurred by replacing it possibly isn't. If the 'wire' in question is at the the end of a few hundred yards of armoured cable taking an awkward route through the plant then replacing it definitely ain't cheap.
Oh I understand the armored cable, generally we run it through a junction box and keep it hooked up to terminals and just break the internal control wiring for troubleshooting. But I guess it all depends on the application and if there is room for junctions.
