Addition of file extension number to a drawing template
Hi all,
I am looking to add a bit of control to my Pro/E drawing files.
I am hoping to use the file extension .1, .2, .3 etc. that Pro/E adds to the end of a part file name e.g.:
tube.prt.1
tube.prt.2
tube.prt.3
I am trying to add a parameter to my drawing template that will identify which file I have created my drawing from.
I suppose it is a roundabout way of creating revision control.
Is there a parameter similar to &dwg_name that I can add to my drawing template?
Thanks for your time
Devrix
tube.prt.1
tube.prt.2
tube.prt.3
Devrix
RE: Addition of file extension number to a drawing template
-AAFuni
Thank you for your reply.
That is exactly my issue.
I would like my drawing to display the 'object version number' my drawing was created at so that I create a revision control. This number will automatically update depending on what object version number my drawing is at.
Do you know if this is possible?
Thanks again
Looking at the OP, it looks like the files are just on disk in some folder. Those sub-extensions are iterations, and not really revisions. Also, drawings will always pull the latest iteration of the model, so linking it to a parameter in the drawing is useless.
My suggestion if you aren't using a PDM system, is to put the revision in the file name, TUBE.A.prt. Then use relations to pull the revision to your drawing.
Ben Loosli
You are correct losslib, we are not using a PDM system.
I will try your suggestion and see how I manage.
Thanks again for your help,
Devrix
