Add Feed per Rev (mmpr) to 5 axis mill post
Hi Everyone,
  Just wondering if anyone knows what needs to be done to add Feed per rev (aka mmpr) to a 5 axis post. I tried outputting a tool path with feeds set to mmpr and just got FMAX for everything. I need to be able to use mmpm for cycles but would like to use mmpr by default elsewhere.
 Thanks in Advance
Cheers
  Steve Griffiths smile
If you want to make apple pie from scratch, first you must create the universe!
RE: Add Feed per Rev (mmpr) to 5 axis mill post
This is not an easy thing to do. Best bet is to contact GTAC and ask them. They should be able to help on this.    1-800-955-0000 push 2/1/1/3 this will get you to CAM support.
Thanks shags72, will talk to them.
Cheers
