Message during closed part
when I close an assembly, the message appear when I close the assembly.
Can I avoid this message ?
If the assembly contain a lot of parts....this message become very, very annoying.
We make a workflow (revision) of single parts or little assembly, not the main assembly that remain writable.
Solutions ?
Solutions ?
Thank you...
Using NX7.0 and TC8.1
RE: Message during closed part
You may need to change Defaults Level if it is read only, look up the top of the dialog.
I'm not sure if this will help or not but might be worth trying.
Cheers
Steve Griffiths
If you want to make apple pie from scratch, first you must create the universe!
I'm using NX7.
Thank you...
Customer Defaults -> Assemblies -> General -> Miscellaneous
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Thank you...
