running de-ethanizer column as stripper column
What is the impact on the process side if we operate de-ethanizer column as stripper column.
RE: running de-ethanizer column as stripper column
Currently, the reflux drum is not running and the overhead moves through jumper line to another plant.
Did you move the feed into the old reflux line? That will give you some more stages.
