bi-directional piston?
Hi all,
I've got a need for a piston that can work both directions - push and pull.
Since it's actuating a frame that moves left-right, I was thinking to use a piston I'd seen before that has two actuators on either end. What is this style called? can you recommend a manufacturer?
Is this even the best way to go? or can I just use a regular push/pull piston?
thanks!
thanks!
RE: bi-directional piston?
double rod end cylinder is what I'm looking for.
Ted
