MgCl on highways
MgCl on highways
MgCl on highways
Has anyone looked at the spray distance of MgCl salt in relation the highway speeds?
Or is the problem more related to locations with lessor perciption?
RE: MgCl on highways
I don't get the connection to Electric Power Transmission and Distribution. Wrong forum perhaps?
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Apperently you don't deal with over head subtransmission and distribution lines. Or you don't know about salt accumulation on insulators.
At issue is the pole fires that occur because of the tracking. If we had some idea how far to expect the salt to spray, then we would know what areas we need to change the insulators on.
I see your March post on the same subject also didn't find any info, so you might try phrasing your question differently, or asking other sources.
I must admit I had to use Wikipedia to understand what you were talking about, here is the Wiki info I found:
A number of state highway departments throughout the United States have decreased the use of rock salt and sand on roadways and have increased the use of solutions of magnesium chloride (often called "liquid magnesium chloride") as a de-icer or anti-icer. Magnesium chloride is much less toxic to plant life surrounding highways and airports, and is less corrosive to concrete and steel (and other iron alloys) than sodium chloride. The liquid magnesium chloride is sprayed on dry pavement (tarmac) prior to precipitation or wet pavement prior to freezing temperatures in the winter months to prevent snow and ice from adhering and bonding to the roadway. The application of anti-icers is utilized in an effort to improve highway safety. Magnesium chloride is also sold in crystal form for household and business use to de-ice sidewalks and driveways. In these applications, the compound is applied after precipitation has fallen or ice has formed, instead of previously.
The use of this compound seems to show an improvement in driving conditions during and after freezing precipitation, but it can damage electric utilities. This occurs in two ways: contamination of insulators, causing tracking and arcing across them, and corrosion of steel and aluminium poles and pole hardware.
What an issue, and so few people understand the impacts. The utilities get the blame for the fires and outages, whilt the highway departments get credit for keeping the highways clear.
The problem is at times with a lack or percipitation, the insulators don't wash off.
And it hard to believe that on this forum, so few people know anything about the problems.
The question is simple, has anyone else found something we haven't?
