Minimum cable bend radius
Q1) Does anyone know how to determine the minimum bend radius of electrical cables?
I am trying to design a cable reeler system for 2 types of cable used in a camera support vehicle:
1) 11mm dia Triax
2) 25mm dia Power cable
Q2) Does anyone know of an easy way to determine how much cable can be stored on a reel, such as a formula or an online chart etc?
Much appreciated - Dino UK
1) 11mm dia Triax
RE: Minimum cable bend radius
Try the enclose site. Consider check the dimensions of standard reels of similar cable. You may find this info in the manufacturer product data or catalogs.
http://www.okonite.com/engineering/bending-ratios.html
http://www.southwire.com/tech/library/papers/ieee_cable_paper.htm#Roller%20Mounting%20and%20Spacing
dydt
Visit
http://www.pirelli.com
http://www.connectworld.net/cgi-bin/iec/MNInstall.html
http://www.iec.net/
http://www.nds.com/solutions/european_cable_form.html
http://www.generalcable.com
etc. for more info
