How do you remove a broken out section in a drawing?
I wanted to try out this feature on a current job, and now I can't remove it.
RE: How do you remove a broken out section in a drawing?
On the view it's showing in right click and go into properties and there is something about 'show broken out sections' or something like that.
Make sure they are set to show the chain out line.
Once this is showing you can select and delete it.
(Sorry if I used a couple of wrong terms, I'm too busy to look it up right now)
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
