Stepper motor overcurrent
My company hold water pipe valves open with stepper motors when water is flowing through.
They also regulate the flow with these steppers.
We have a stepper motor with a rated current-per-phase of 324mA (=6V/18.5R)
My company are proposing to operate this motor in full stepping mode, with a chopper driver, with 750mA average current in each of the two motor phase windings.
Here is the stepper motor datasheet..................
The stepper motors are the UBB(1/5), 6V, 18.5 Ohms per phase type on this datasheet:-
DATASHEET:
http:/ /www.auf-v ertrieb.bu siness.t-o nline.de/p df/UBB.pdf
-Please can you second my opinion that this is madness?
-this is way too much current for this motor?
DATASHEET:
http:/
RE: Stepper motor overcurrent
The power dissipation of 750mA is over 5x greater than that of 324mA. That would be very hard to get rid of.
Curt Wilson
Delta Tau Data Systems
