Carbon Fibers and Steel Plate as an additional reinforcement
Good day,
I am on the retrofitting project, and I resorting in to two methods
1. to use a carbon fiber to reinforced the prestressed slab
2. to use a steel plate with epoxy resins
Its the first time that I encounter these method. Do you have any good references or sample design regarding these methods?
thank you in advance
Poems are made by fools like me, but only God can make a tree. engineers creates wonderful buildings, but only God can creates wonderful minds
RE: Carbon Fibers and Steel Plate as an additional reinforcement
ACI440.2 "Guide for the Design and Construction of Externally Bonded FRP Systems for Strengthening Concrete Structures".
A textbook by Lawrence Bank "Composites for Construction Structural Design with FRP Materials".
Concrete Society Technical Report 55 "Design Guidance for Strengthening Concrete Structures Using Fibre Composite Materials".
Is there anything in particular you are looking into?
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
i am also looking for a sho-bond method,but i cant find useful resources regarding these method
I am not familiar with the sho-bond method.
Qshake
