Curve driven pattern around the perimeter
I would like to pattern the hole around the sketch line (highlighted blue). The sketch like is an offset of the outside edge.
The curve driven pattern is not letting me do this I think as it says the curve must be composed of a single contour.
It is important to select the curve as a whole and not do it reputedly for each contour as I would like equal spacing of bolt holes.
Thanks in advance!
Thanks in advance!
RE: Curve driven pattern around the perimeter
-handleman, CSWP (The new, easy test)
Were you affected by the recent quake?
