Heat Treating 4130 for toughness
We are experiencing problems coming up with the best "recipe" for heat treating a 4130 part for toughness (not hardness). Can anyone provide the best parameters for:
-    Austentizing
-    Quenching
-    Tempering
RE: Heat Treating 4130 for toughness
Part thickness?  1575 F, water quench.  Temper 1000 MINIMUM.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
The part is 0.070" thick. We are currently doing the following which is resulting a a brittle part and a 43RC:
- 1585F for 1 1/2 hours
- Oil quench to room temp (oil maintained at 60°c)
- Temper at 750F for 2 hours
- Air cool to room temp
What have you found to be the most significant factor in making 4130 tough?
your hold time at 1585 is way too long.  Try ~20 min.  Then temper at 1,000 F minimum.  What hardness do you need?
We are quickly learning that toughness is more critical than hardness in this application. We were originally shooting for a hardness of RC 43 - 45 to resist drilling/punching etc. This is no long as critical as toughness - resistance to cracking/tearing.
I have attached a drawing so you can get a better idea of the shape of the part.
Hillmd92 Try again with the attachment
You should get Rc32 if you temper at 1,000F.  Toughness of 4130 increases dramatically from 900 F to 1000F.
Many high pressure gas cylinders (oxygen, etc) are 4130 and tempered at 1,000 F min.  Cylinders are VERY tough.
If cost counts, consider using 1030 and water quenching.  Will be approx. the same hardness and toughness in such a thin part.
What happens over 1000F?
~Rc28, very slight increase in toughness.  Use a TRUE temp. of 1,000 and you'll be OK.
Time for dinner!
Have you tried fast air cooling as your thickness is low.
Thank you very much for all the help, I think I am on the right track.
The next challenge I am facing is hydrogen embittlement after Rohs Zinc plating.
We have notice a significant decrease in toughness after plating. So far we have tried baking the parts within 4 hours after plating at 375°F for 4 hours but we are still seeing the problem. I assume we need to lengthen the baking time, is there any rules for how long? Is there anything else I should be aware of with 4130?
Use 24 hr at 375F, but I don't think HE will be a problem after you temper at 1000F min.
