Minimum height of grade ring required for concrete manhole
The minimum height of concrete grade ring for manholes/sanitary manholes is specified as 150mm on IFC dwgs for a project I am working on.
I got a phone call from Conctractor saying that this minimum height requirement could not be met because the elevation of some manholes installed was higher, and as a result, the maximum height of 75 mm for grade ring was the only option to choose.
As a structural(foundation) engineer, I am wondering what risks I will have by accepting this height (75mm) in lieu of 150mm. By using this height, the final grade will be very close to the design elevation (maximum allowable deviation for grade elev. is 25mm).
Thanks for your tips and advice in advance.
RE: Minimum height of grade ring required for concrete manhole
Thanks guys for your opinions!
@ beton1, I am not sure, but I would say why not? For clarification, what specifies 150 mm as minimum is not a code but our standard drawing (either coming from a code or a typical practice?).
