Code Problem with UMAT
Hi:
I am trying to model residual stress as a result of temperature change using linear isotropic hardening equation.
1. I used USDFLD to calculate young's modulus (as FIELD(1)), poisson ratio (as FIELD(2)) as a function of temperature
2. I calculated the corresponding yield stress (FIELD(3)) as a function of temperature too in USDLFD, and stored as statev.
3. I used UEXPAN to calculate thermal strain (EXPAN(1) which I stored as a STATEV variable, Dthermal strain =coeff of expan*DTEMP and stored as another statev.
4. I got a UMAT code for isotropic hardening plasticity,
  I calculated: FIELD(1)=EYoung(T), FIELD(2)=ENU(T)
      EBULK3=FIELD(1)/(ONE-TWO*FIELD(2))
      EG2=FIELD(1)/(ONE+FIELD(2))
      EG=EG2/TWO
      EG3=THREE*EG
      ELAM=(EBULK3-EG2)/THREE
C     ELASTIC STIFFNESS
C
C
      DO  K1=1,NDI
        DO  K2=1,NDI
           DDSDDE(K2,K1)=ELAM
      END Do
        DDSDDE(K1,K1)=EG2+ELAM
      End Do
      DO  K1=NDI+1,NTENS
        DDSDDE(K1,K1)=EG
        End Do
C
C    RECOVER ELASTIC AND PLASTIC STRAINS
C
      DO  K1=1,NTENS
         STATEV(K1)=E(K1)
         STATEV(K1+NTENS)=PE(K1)
 80   END Do
C  Also recover equivalent plastic strain
      Call ROTSIG(STATEV(1),DROT,E,2,NDI,NSHR)
      Call ROTSIG(STATEV(NTENS+1),DROT,PE,2,NDI,NSHR)
      PEEQ=STATEV(1+2*NTENS)
C    CALCULATE Predictor STRESS FROM ELASTIC STRAINS AND THERMAL STRAIN
C
      DO  K1=1,NTENS
        DO  K2=1,NTENS
           STRESS(K2)=STRESS(K2)+DDSDDE(K2,K1)*(DSTRAN(K1)-STATEV(2))
            STATEV(1)=STATEV(1)+STATEV(2)
            E(K1)=STRAN(K1)+DSTRAN(K1)-STATEV(1)
     1
C    IF NO YIELD STRESS IS GIVEN, MATERIAL IS TAKEN TO BE ELASTIC
C
      End Do
      End DO
C
C       MISES STRESS
C
        SMISES=(STRESS(1)-STRESS(2))*(STRESS(1)-STRESS(2)) +
     1          (STRESS(2)-STRESS(3))*(STRESS(2)-STRESS(3)) +
     1          (STRESS(3)-STRESS(1))*(STRESS(3)-STRESS(1))
        DO  K1=NDI+1,NTENS
              SMISES=SMISES+SIX*STRESS(K1)**2
 90     END Do
        SMISES=SQRT(SMISES/TWO)
        STATEV(3)=SMISES
C
C       HARDENING CURVE, GET YIELD STRESS
C
C
C       DETERMINE IF ACTIVELY YIELDING
C
        IF (STATEV(3).GT.(1.0+TOLER)*STATEV(5)) THEN
C
C         FLOW DIRECTION
C      Actively Yielding
C Seperate the hydrostatci from the deviatoric stress
C
          SHYDRO=(STRESS(1)+STRESS(2)+STRESS(3))/THREE
          DO  K1=1,NDI
             FLOW(K1)=(STRESS(K1)-SHYDRO)/STATEV(3)
               End Do
                  DO  K1=NDI+1,NTENS
                   FLOW(K1)=STRESS(K1)/STATEV(3)
                    END Do
        END IF
C       SOLVE FOR EQUIV STRESS, PEEQ from NEWTON ITERATION
          HARD=0.0
          DPEEQ=0.0
          DO  KEWTON=1,NEWTON
             RHS=STATEV(3)-EG3*DPEEQ-STATEV(5)
             DPEEQ=DPEEQ+RHS/(EG3+HARD)
             END Do
             IF(ABS(RHS).LT.TOLER*STATEV(5)) GOTO 140
 130      CONTINUE
          WRITE(6,2) NEWTON
 2        FORMAT(//,30X,'***WARNING - PLASTICITY ALGORITHM DID NOT ',
     1        'CONVERGE AFTER ',I3,' ITERATIONS')
 140      CONTINUE
          EFFHRD=EG3*HARD/(EG3+HARD)
C
C       CALC STRESS AND UPDATE STRAINS
C
          DO  K1=1,NDI
             STRESS(K1)=FLOW(K1)*STATEV(5)+SHYDRO
             PE(K1)=PE(K1)+THREE*FLOW(K1)*DPEEQ/TWO
             E(K1)=E(K1)-THREE*FLOW(K1)*DPEEQ/TWO
      END DO
          DO K1=NDI+1,NTENS
       END DO
          PEEQ=PEEQ+DPEEQ
          SPD=DPEEQ*(STATEV(5)+STATEV(5))/TWO
C
C       JACOBIAN
C
          EFFG=EG*STATEV(5)/STATEV(3)
          EFFG2=TWO*EFFG
          EFFG3=THREE*EFFG2/TWO
          EFFLAM=(EBULK3-EFFG2)/THREE
          DO  K1=1,NDI
             DO  K2=1,NDI
                DDSDDE(K2,K1)=EFFLAM
        CONTINUE
             DDSDDE(K1,K1)=EFFG2+EFFLAM
       END Do
         END Do
          DO  K1=NDI+1,NTENS
             DDSDDE(K1,K1)=EFFG
      END DO
          DO  K1=1,NTENS
             DO  K2=1,NTENS
                DDSDDE(K2,K1)=DDSDDE(K2,K1)+FLOW(K2)*FLOW(K1)
     1                                       *(EFFHRD-EFFG3)
        End Do
          END DO
C
C STORE STRAINS IN STATE VARIABLE ARRAY
C
      DO  K1=1,NTENS
        STATEV(K1)=E(K1)
      STATEV(1+2*NTENS)=PEEQ
      END Do
      RETURN
      END
Questions: 1. error LNK2005: _UMAT already defined in uexpanSS316LonSS316L2.obj
fatal error LNK1169: one or more multiply defined symbols found; unable to fix the error.
2. Is my logic correct (i.e. to substract thermal strain from elastic strain and calculate stress, if stress exceed yield stress then store values as plastic strain).
3. I would like to incorporate volumetric strains also in my model to study phase transformations, can anyone give me suggestions?.
