Developed Drafting View
An unusual question.....
I need to create a drafting view of a developed (flattened engine casing)
If you imagine a jet engine casing, I want to create a view on a drawing as if I had cut the casing down one side and flattened it out.
It's only for pictorial purposes, so does not need to be mega accurate, but does need to be representative & associative.
The only method I have come with thus far is to take folded views at regular intervals, rotate the views, clip them a bit and align them all.
As you can imagine this is a pain, and takes a long time. I am toying with the idea of trying to create some kind of NX open script to do this.
Has anybody got any better ideas?
I'm using NX6
Cheers,
NXj
I'm using NX6
Cheers,
NXj
RE: Developed Drafting View
I think what I did was project the curves normal to the surface and onto a flat plane - the flat plane was on the center axis of the jet engine housing.
I don't have time to play around today to see if I can repeat what I did, but I hope to get back to you.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I'll have a dabble tomorrow.
NXj
I did it in four sectors to keep it simple.
you have saved me a lot of time :)
Many Thanks,
Nxj
