Dyno correction factor vs air density
I posted the question on the thermodynamics forum because I did not feel it was really an automotive based question. I have still yet to confirm this so I am posting here geared more towards an automotive question. I am not trying to cross post so I hope the moderator understands, just looking for another point of view.
Basically I would like to know why the cf will indicate more power when calculated from two atmoshpere that have the SAME air density, but one is made from a higher pressure?
Atmophere A: 70F 29inHg density 1.163kg/m^3
Atmoshere B: 80F 29.547inHg density 1.163kg/m^3
My assumption based on the ideal gas law is that both atmoshperes will appear identical to the engine and therefore make the same power.
using the cf equation:
atmosphere A = 1.002
atmoshpere B = 0.990
So is the cf equation correct that atmosphere B will create more power or is the equation just an approximation and really should make the same power?
RE: Dyno correction factor vs air density
There are various theoretical reasons why pressure and temperature have different effects on the combustion and realized power even where the same density is achived. However, that discussion is not really needed here, although it is somewhat baked into the equation used by nature of those powers being the best fit through the ranges the correction factor equation is relevant for.
So do you feel it is plausible that you may make the same power with the same density eventhough one air sample comprises a higher temperature or pressure?
For small variations in temperature or pressure, I would expect the difference in power generated to be insignificant for the same air density. However, for large variations in pressure/temperature, even where you net conditions that achieve the same density, I would expect the differences to be noticeable.
E.g. If we take the CF coefficients of pressure and square root of temperature, we should expect 100 hp at sea level and 100 deg F to correlate to roughly 93 hp at 4,000 feet and 22 deg F (which should be similar air density if my math was right). That's not earth shattering, but it's noticable, and it's on the order of magnitude of what we should expect based on the factors above that cause the differences.
You do feel that there will be an independent temperature and/or pressure effect. And you feel that the cf equation, altough it may not be calcualting the horsepower exactly, it is correct that it is showing an increase in power when the temperature and pressure are higher at the same density.
In other words, the cf equation does NOT have enough error that it could have just as easily shown the power being less.
1) There will be independent temperature and pressure effects beyond just the effect on density.
2) The CF equation is matching a trend in a narrowly defined window of pressures and temperatures. Within that window, I think it is correct that, generally, a higher temperature/pressure at the same density will give you higher horsepower.
To respond to your last statement:
The CF equation matches a real-world situation with a smooth curve. Generally, it will trend in the right direction. There may be times, in a real engine, where a trend may briefly reverse (e.g. when a mode behavior occurs, such as a new fueling table being used at certain temperatures or pressures, an actuator saturates, etc.), but generally the CF equation is correct if used within the data ranges it is designed for.
Previous posts are correct however. Elevated air temperature has less effect than reduced pressure (density being equal). For one thing, hotter air will absorb less heat (and therefore suffer less temp rise and density fall) during the intake process.
If the value is opened for a long enough period of time to let the cylinders equalize with the atmosphere then the density in both cylinders will be the same. But if the valve is opened only for a short time then the rate at which air flows into the cylinder will be dependent on the pressure differential, thereby the atmosphere with the higher pressure will fill the cylinder with more air while the valve is opened and be able to make more power.
I am sure the higher temperature will also allow for easier combustion, but I think this is a much smaller effect then the pressure pushing the air in.
Does all this sound reasonable?
Uhmm, my initial reaction to that is that it is fallacious to consider only the ambient pressure effect on the intake side, since the same ambient pressure is presumably also acting on the exhaust side.
Hemi, that depends upon the timing of valve events. You are not worried about energy to fill and empty the cylinder, you are primarily looking at how much air ends up in the cylinder at the end of the intake stroke. When your exhaust valve is closed, the differential pressure at the intake valve is dominated by the dynamic volume and intake manifold pressure, and it doesn't much matter what exhaust pressure you were working against. It will slightly change your dead volume, which is ignored, introducing some error.
Good info - thank you. Is it only good for a narrow range because that's where the assumptions are good?
