how to force a start position
hi all
i have a triangular pocket that needs milling out.in fact i have 300 triangular pockets to mill out
i have created a point in the middle of this triangle so that i can u drill to depth.i now need to get a milling cutter into this hole and mill this pocket out.
how can i force the milling cutter in the hole.
i am using nx6 ,boundary milling,contour profile.at the moment the tool goes in off centre and follows the profile ,stepping out 1.25mm on each pass until it reaches the walls.this may sound a easy problem to solve but i am scratching my head a bit.
the job is more complicated than it sounds as the triangular pocket is on the side of a truncated cone and the base of the pocket is curved
RE: how to force a start position
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
Bill
