Same position in all
those are the steps:
1)Created an assembly
2)Created two arrangements (one default with all and one without some components)
3)Inserted a sub-assembly and mated
4)When I switch from one arrangement to the other, the sub-assembly change the position.
5)I try to set 'Same position in all' to this sub-assembly, but I'm not able.
Any suggestion to avoid that that this sub-assembly change his position ?
Thank you...
Using NX7.0 and TC8.1
