Excel table in MicroStation
After embading an Execl table into a Microstation file, I am unable to open the MicroStation file again. Does any body has gone through such problem? or any body with an idea how I can get back the MicroStation file? That is all I want.
Thanks in advance
Thanks in advance
RE: Excel table in MicroStation
That said, when you link, understand that once the link is established, you cannot resize or rotate the MS element. So I make sure that I have it the size that I want when I first bring it in, and if my file is rotated for some reason, I put the spreadsheet off to the side and self-reference it in.
Good Luck
Robert Weber
Maurer-Stutz, Inc.
Peoria, Il
309-693-7615
www.maurerstutzinc.com
http://www.askinga.com/
EDG may be able to "clean" whatever anomoly is preventing you from opening your file. If you are already familiar with EDG, I apologize for insulting your intelligence.
