Macro code to run reports on solid edge assemblies
If it exists somewhere..or can someone advise me of the code required to index down a list of solid edge assembly files that I choose, in an excel macro to run a report, copy and paste to a worksheet in excel. I have to do this manually and its time consuming so any pointers in the right direction would greatly be appreciated. Thanks in anticipation.
I have put this also on general engineering programs.
The only code that i need is the bit for the macro to do the equivalent of mouse right click on a named file then select a solid edge command...ie report, the rest i can do myself. Hope thats clear.
Thanks Nodski
