Arrow label of the detail view
Hi to all,
Is it possible change the position of the arrow indicated ?
Thank you...
Using NX7.0 and TC8.1
RE: Arrow label of the detail view
Best regards,
Michäël.
NX4.0.4.2 MP10 + TCE 9.1.3.8_build_0711 / NX6.0.5.3 + TC8.1 Unified / NX7.0.0.9 (native) / NX7.5.1.5 (native)
Belgium
Thank you...
So in the example that you showed - if the point used for the size of the circle was a screen pick 180 degrees from where you put it, you would have been in much better shape that where you were.
