ASME III vs ASME IV
ASME III vs ASME IV
Our company is in the process of procuring an AMSE code for pressure vessels. We have to decide to procure ASME III or ASME IV as we have a need to use the code on both nuclear and standard Pressure systems. What are the key differences between the codes and is everything within ASME IV covered within ASME III??
Jimbo
EngCo Solutions Ltd
www.engcosolutions.com
RE: ASME III vs ASME IV
Jimbo
EngCo Solutions Ltd
I think you should get the whole Code ASME.
some $15K USD, you will get it back in no time with the knowledge you will get.
An eng designing a sect III vessel may not be able to design a simple Sect IV vessel, or the other way around even ahrder.
take it that way.
