Bearing Load
Bearing Load
Hi... Can anybody help my in applying bearing load as a pressure in Patran 2010? I want the load to be applied over a 60degree region of the cylinder only.
Thanks in advance
Thanks in advance
RE: Bearing Load
How I can write a batch file for Nastran to run some bdf files in sequence?
Thanks a lot,
Art
RE: Bearing Load
http://www
For the bearing load, You should create a cylindrical coordinate system and apply the load in this coordinate system.
If you want the load to be applied as a function of the angle you should make a field.
Onda
