How to print an array with variable dimensions in VB
Does anyone know how to print an array with variable dimensions in VB?
The following code won't do what I want, it outputs only one column, not rj (10 here) columns.
Open "debug.txt" For Output As #1
rm=10
rj=10
For i = 1 To rm
    For j = 1 To rj
      Print #1,  my_array(i,j)
    Next j
Next i
Close #1
What is the right code for my purpose? Thanks for your help.
Jack
RE: How to print an array with variable dimensions in VB
'You need Something like this
dim fileNum as integer
'get the free file number
fileNum= Freefile
Open "debug.txt" For Output As fileNum
'allow for whatever the array has been dimensioned to
rm = ubound(my_array,1)
rj = ubound(my_array,2)
For i = 1 To rm
    For j = 1 To rj
       print fileNum,  my_array(i,j), 'note the trailing commas
    Next j
    'new line
      print fileNum, vbCrLf
Next i
Close #1
