How to turn the GM TEST off??
Hello all,
I turn the GM TEST on by /MO QERY GT, but I have no idea to turn it off.
Now I can't trim my surface in normal because of the internal error as the following list:
*** Internal error in function ms5fatr/CopyUserFace
*** - gt3faco returned a 40415 when called by
*** ms5fatr/CopyUserFace at position 3635
*** - Aborting ms5fatr/ms3trva at position 3335
*** - Aborting ms5fatr/ValidateData at position 100
Have anyone can give some good idea??
RE: How to turn the GM TEST off??
It sounds like there is a problem with the surface.I would try the following:
1. Offset the surface by a value of 0, untick "keep original surface"
Or
2. Extract the surface to a new part
Or last resort....
Export the surface as an iges or step and import to see if errors are removed.
I guess you could always rebuild the surface..
