fan torque vs speed general relationship
I was under the impression that the torque-speed characteristic for fans is similar to centrifugal pumps pumps, generally torque ~ speed^2... (not exact but pretty close).
The attached excerpt from "COMPUTER ANALYSIS OF POWER SYSTEMS"
by Arrillaga and Arnold suggests that a linear relationship (torque ~ speed) is generally more appropriate for fans.
Is there any basis for that? Or are they out to lunch?
(2B)+(2B)'  ?
RE: fan torque vs speed general relationship
Both the 1st and 3rd links say that for constant impeller or wheel diameter: Power~N^3 which implies Torque~N^2
The middle link has:
(W1/W2) = (D1/D2)^5  (N1/N2)^3  (ρ1/ρ2)
where W1/W2 is power ratio D1/D2=1 if we're fixing the wheel diameter.   IF the system operates close to atmospheric pressure with maybe 0.15 psi or less dp, then the absolute pressure varies by less than 1% and rho is for all purposes constant.  I think most ventilation and cooling type fans do not fall into this category.... ok to treat density as constant.  Then again power proportional to speed^3 and torque proportional to speed^2
(2B)+(2B)'  ?
